Pilot drilled mounting of C02-16 rudder cable pulley assemblies.
Cut AN3C-10A to lenth and shaped the tip per D02-17 using the drill press and a file.
Assembled the components for the canopy latch hook rail assembly, D01-04. I found an exact fit for the specified 3" metal drawer pull at Home Depot. The item is a Liberty brand pn P604DAC-SC-C5 (www.libertyhardware.com). It is a satin chrome steel handle.
